Tail_Gunner
Thread starter- Joined
- Jan 13, 2006
- 6,237
1993 alpah one gen 11 3.0l merc
Took the boat out for a quick run, ran about 1-2 miles when the stern drive developed a high pitched wine or ginding (Like a belt grind on a car).
Immeditaley killed the motor and went into shore. Loaded up took it home put on the muffs's started the thing up slight grind still present. Notices no water comeing out of the pump (lower unit).
Replaced the water pump still no water coming and the grind is still present. Took off the upper unit and the diver line knuckles appear ok they rotate quite freely.
One thing i did notice the lower unit oil did have some shaving's
Could this be the gears? it sound;'s like that is where the grinding is coming from
