Stern Drive Question
krobbins
I pulled the upper housing off and when i put it back together after 3-4 hours fighting with aligning the shaft into the transom, i must not have the shift cable hooked up correctly inside the upper housing because it cranks and it is engaged (prop spinning) and engine shuts off if i try to move forward or reverse. I disconnected shift cable from shift plate and tried to move it and it wont slide in or out, i even tried moving the prop at the same time but i cant move cable. Will i have to remove the upper housing again??? I hope not!
My boat is a 1987 SeaRay with 4 Cylinder mercruiser I/O with Alpha one.
Re: Stern Drive Question
Ayuh,...... My Guess is,.... That's where th Problem is At...
subcrx
sounds like you jammed something up
bwingler
Did you put the shifter in forward prior to removal?
Muqwump
When you get the drive back off...... Put it in foward gear then when you reinstall, make sure you are keeping tension the prop in a counter clockwise direction. Check the pump while you are back in there also if you had been trying to run it.
