sterndrive will go in/down only
yonu
Ok all I am hoping for some help I am trying to get the tilt on the sterndrive to behave it will go in/down and but up I hve power in both Directions at the switch nut no reaction on the stren drive any ideas would be great oh and I have replaced the solenoid and it is on a 73 fiberform with a 351W
Thanks,
Reg
Re: sterndrive will go in/down only
Are you getting any sound from the motor or solenoid? any clicking back there. The solenoid needs power as well as ground to work. A bad connection on either would do it. Before you go after the trim motor, test the solenoid is closing.
oldjeep
Easy test is to reverse your up down wires at the switch. That'll tell you if the switch is bad, or point to something further down the line (wire, ground problem, solonoid)
yonu
ok thanks for help guys turns out it was solenoid wiring as I rewired it the same way as the old solenoid turns out it must have been wrong but I have to motor working in both directions but the outdrive doesn't raise my question is this and will sound extremely stupid the psi gauge reads 15psi what should the psi be and does it build pressure or does it have to be charges since there is a valve stem on the top?
again thanks and sorry for the stupid questions
tHanks,
Reg
yonu
if it helps here is a pick of the solenoid and pressure tank setup the gauge is currently at 15psi when I got the boat it was at 60psi and has stayed there since I had it i bled it off like a dumbass
Thanks,
Reg
Thanks,
Reg
Ayuh,... The pressure tank is part of a hyd. steerin' system....
There's a couple of screws down under the pump's motor ya need to take out, 'n Fill it with Oil....
yonu
ok cool I was slightly worried
I assume the simplest way to get to them is to take the bolts out and lift the motor out to get to them?
Thanks again will post my results,
Reg
Ayuh,... I can't see 'em,... Look on the corners, under the round part,...
2 screws, nearly side by side, 1 is fill, 1 is vent, fill til it comes out the vent....
yonu
ok thanks I will have a look tomorrow as the weather is lousy this evening
thanks again,
Reg
yonu
hey stupid question what type of fluid is supposed to be used?
Don S
Here is from the manual. While the manual calls for engine oil, check it before you fill it. If it's red, it's probably ATF. Best not to mix the two.
yonu
thanks wanted to make sure wasn't sure. Which manual I do need for the system and where I can get a copy?
Thanks,
Yonubear
yonu
thanks that will help a lot I checked the fluid and it is all milky so I guess tomorrow I will drain the system and refill it. I would assume I can treat it like car brakes and just keep bleeding until the fluid runs clean?
Thanks,
Reg
