Re: Stiff steering to left - 1991 Force 70 hp
Had the identical problem with my 235 Johnson, on a 24 ft CC Mako. After much searching & "grumpy" steering, one day when the motor was full up for trailering, I noticed that the skeg had apparently gotten whacked, such that it was no longer perfectly vertical & straight, but instead had a slight cruvature (sorta like a crescent moon) at the leading edge.<br /><br />I carefully straightened it (unless you know something about metals, I'd suggest you have it done by a professional), and now its a charm to turn in either direction...<br /><br />Good Luck...
