Stiff throttle in my 1989 larson what can I do to fix or make better
dkorzun21
I have a 1989 larson i/o boat and my throttle is a little stiff. What can I do to try and loosen it up a little bit? And where should I be looking to do this? Dont want to replace the cables right now because I just spent 400 to have the steering cables replaced. All help would be appercaited.
danond
Re: Stiff throttle in my 1989 larson what can I do to fix or make better
You have to replace the cables. Sorry, no shortcuts here.
cooter2506
He is correct but you can isolate which one it is by removing your control cable fro the shift bracket and shifting to see if it is that one or your lower shift cable.
Ayuh,... The Controller controls both the Throttle,+ Shifting,..?? Right,..??
You'll have to figure out Exactly what's binding to find a Cure...
