Stiletto 13x21 Thrust Washer (PICS) Question
krakatoa
Well HELLO Guys!
Just upgrade from aluminum to SS propeller since the last one just broke up after 4 years of fun...
The new one is a Stiletto 13x21 with hub kit already installed
My concern is the following:
If I use the Quicksilver brass washer that is over 1/2 inch the propeller have a nice gap like this one...
If I install the propeller with no washer at all I mean only like the 2nd picture its go all the way down with no gap and feels rought when turn by hand and the worst is If I torque with the socket the propeller doesnt turn by hand ...
So I decided to exchange the brass thrust washer with a SS one more slim than quicksilver like this...
with the following result
I didnt test on water yet but the prop turn nice and freely by hand with the proper torque. Now the big question is If this SS washer will hold the job without any risk of damage in prop shaft or any other else.
The setup in the picture 3 works but my concern with this one is that the splines are over 1/8 inside the propeller hub. Im trying to be as most accurate regarding splines alignment.
Would like to hear from you guys.
As always BIG THANKS!!
jestor68
Re: Stiletto 13x21 Thrust Washer (PICS) Question
That doesn't look like an actual "thrust washer".
It looks like a washer from a hardware store.
krakatoa
Yest, it is a washer from a hardware store, thats why Im asking if this one could do the job. I will take additional pictures of the splines with the quicksilver thrust washer installed.
Texasmark
Nothing wrong with the "nice gap". I have one on a similar engine running a Ballistic SS. If the Stiletto length is not comparable to OEM props and you bought it from I boats, they list the proper thrust washer on the page where you order your prop. Besides you need room for your prop to function in the "slip clutch" mode while running in F gear where the prop shaft moves up and down slightly moving the prop back and forth slightly.....Put the shifter in F and push on the prop from the rear...it's spring loaded.
If you didn't buy from them, go to the top of this page and get in the prop arena, punch in your numbers, find your prop, pull it up and look for the specific thrust washer on that page and buy it. Forget the "hardware store" washer. Thrust washers are tapered to fit the taper on the shaft. All of the forward thrust of the prop is against them and they along with the prop nut allow the slip hub in the prop to perform normally.
Mark
Frank Acampora
That washer will not stand up to thrust loads. It won't happen immediately but eventually it will either jam onto the shaft or slide down it allowing the prop to wear the gearcase..
You need to do something more like I have shown in these photos. The split stainless shaft collar will grab the shaft --IF there is a stepped section behind the original thrust washer and you tighten the locking screws really well. Stainless flat washers space the prop the correct distance out on the shaft. The correct size split collar will cost around 30 bucks at Fastenal. (if they are located in P.R.)
Obviously, your Mercury (Or Force with Mercury lower unit) is different than the Force I did this to and you will need to be slightly different. You may not even be able to do it. However, I had the same problem and the blades of the Ballistic prop did contact the exhaust snout so I needed to move the prop further back into the gearcase.
Nope,... You need the proper thrust washer that matches the taper of the prop shaft, 'n matches the prop,....
krakatoa
Busy Days but Im back!!!
Now I do not know what Im thinking about but confused when saw splines did not meet exactly with the hub, thats why I try to use the "ss hw washer", anyway never ran the OB with this washer but take a look at this pictures.
Look how far back the shaft splines are when use this hub washer
Propeller gap from gear case
Now using the quicksilver 13191A1 Original Thrust Washer,this one goes deep inside against the thrust,
the splines are closer to the outside of the hub
and finally gap between gearcase and prop, maybe is just about 1/8 maybe liitle more closer to the gear case its not a big difference
krakatoa
View attachment 227583View attachment 227584View attachment 227585View attachment 227586View attachment 227587
Yes there is a stepped section at the back of the shaft, looks like a good idea but the quicksilver washer do the job, its possibly that the hardware washer will ruin the shaft some time, never took the risk to allow it. The OB is a 1993 Mariner 115HP
krakatoa
Mark
Mark you are right the Stiletto lenght is not comparable to OEM props, maybe I get confused at this point, since after 4 years with same aluminum prop I forget that "little" detail and expect the Stiletto fit as an OEM.
Anyway at the end of the day I test the prop but do not like it. Too much pitch for my OB definitely will stay with 13x19 and for ski or heavy load will keep my Rapture 13x17 and will sell this new one.
Thanks to all for advice.
