Rich976usaf
Thread starter- Joined
- May 9, 2007
- 61
Hey again guys. Im still having this problem. I just wanted some input before i go and buy a $$ expemsive fuel pump. I am restoring this 1985 evinrude 115 hp ob. I have rebuilt the lower unit, cleaned the carbs, water pump.
The problem im having is a cant get enough power to get up on plane. I idle fine and run about to 1/2 wot above that i bog down. But if i back off then i still run. I get small pulses of power sometimes. Or if i "hit it" it revs up nice then usually stalls. It might help some if i keep squeezing the primer bulb. I thought it was a problem with the tank, so i bought a new tank. I was getting goo from the tank in the filter. The problem still persists. I have changed all the fuel lines. Does this sound like a weak pump. I have pulled the VRO pump that I have converted to premix and closed off the oil lines. I ran it with the cover and air box off. I could see the fuel spraying into all four barrels. So how could it be the fuel pump. Am i not getting enough fuel, I cant tell? Could this problem be electrical?
Where is a cheap place to buy a fuel pump. Can i convert to a different style pump? What are my options. What do you guys think? Any advice is appretiated.
I pulled the pump and opened it up the diaphrams look good. there is a one way valve for the fuel in line built into the pump that works well. I checked it by blowing and sucking on the line. (mmm gas tasty) So then i checked the engine pressure part of the pump in the same mannor. I could pull air through it easily. but when there was pressure on that port i could blow through it with resistance. Like there is a leaky valve I cant see. Do you masters know if that is right or wrong.
I just dont want to buy a $200-250 pump if its not the problem.
