1slowcamaro
Thread starter- Joined
- Jul 29, 2012
- 13
Still having the same problem with my 1985 140. it acts like it has a serious miss at idle. only when in gear. in neutral it runs great but as soon as you put it in gear it sputters and surges and dies. if you throttle it up quickly it runs great.
compression is exactly 120 across The board
i have changed plugs.
cleaned and rebuild carbs
checked for vacuum leaks
the spark jumps a 1/2 gap
8 degrees of timing at idle
all fuel lines are new
im at a loss here
someone told me since its a big bore 140 that it needs 2 fuel pumps to give it enough fuel at idle does this sound right?
it has an old style fuel pump the vro is gone
im at a loss here
