still no spark
nikolass
i have a 60 hp evinrude there is no kill switch that i can see and all the grounds are good the little black ignition box has some corrosion around where the wires are I WANT MY SPARK!!
JB
Re: still no spark
You need to tell us the model number, Nikolass. There are at least four very different 60hp Evinrudes.
Pony
Re: still no spark
JB theres a post further down that nikolass made. I believe he is referring to the 1971 version.
Nikolass, you don't have to start a new thread.....everyone can follow along and help you better if you post in your original thread.
nikolass
Re: still no spark
well i went and looked at the motor where is the serial number located i looked all over the only thing i found was on the flywheel it said 1969 v4 -> / b
Joe Reeves
Re: still no spark
There should be a plate on the port (left) transom bracket (bracket that bolts the engine to the boat).
dsinger
Re: still no spark
how did you clean the grounds. If you see corrosion clean it when did you start the thing last and has it ever had spark for you
dsinger
Re: still no spark
I am asuming when you say spark you have seen all four plugs spark with your own eyes. Just because it fires don t mean you have spark enough to operate the beast
nikolass
Re: still no spark
model number 60073B
serial number J01020
i used a wire brush on every bolt and nut that looked like a ground should i take the flywheel off and use some light sandpaper on the points?
dsinger
Re: still no spark
I use steel wool but the real mechanics might say I am crazy
tashasdaddy
Re: still no spark
Nik, go to 'boatpartstore.com' click trouble shooting , under johnson click page 24. should help you.
nikolass
Re: still no spark
i took the flywheel off and sanded down the points and steel wooled it um i used a current tester for the coil and im getting no feedback so i think its the coil?
Merrill
Re: still no spark
I had to replace the coils on the last 2 motors I had. You can often tell a bad coil fairly easy as they are cracked and corroided. Often you can see where they are arcing to ground. I use 1000 grit sand paper to lightly clean the points.
