Still not done
Fatbs
The ignition switch is now bad. I have another switch but it is not a force ignition and the only wire that will not not hook up to it is the light blue magatno wire. This wire only runs from the ignition to he wiring harness on the side of the motor and stops there. Do i need this wire hooked up?
Jiggz
The blue wire is actually the ground wire to stop the motor. It is jumpered to the black wire in one of the terminal boards either under the dash or in the engine block. There are two "M" terminals in the ignition switch, one is white while the other is blue. When you turn the switch to off, there two wires connect together grounding the CD packs thus shutting down the motor. A kill/stop/lanyard switch will be in parallel to these two terminals.
