Still over heating
I noticed oil leaking from that little hole on the bottom starboard side
of the housing
When I ran it with earmuffs, I noticed water coming out of it.
I know gear oil shouldn't be coming out of it. ( Ididn't run it yet. I noticed the water
before I took it apart)
Ayuh,.... Yer drive has a bad seal, that little hole drains the inside wet area of the housing,...
Water wet, not oil wet,....
kcfromohio
The water pump base they sold me was the wrong one. When I pump oil into the gear case the oil came out the bottom of the
water pump base. I just got a new one the right size. Hopefully I will be on the water this afternoon!
kcfromohio
No Title
Latest... I put the new impeller pump base in and pressure tested it.
(I held my thumb over the hole and pumped a little gear lube in it)
I was having a little trouble with the copper water tube that goes
into the upper gear case housing. I ran into another can of worms...
I ordered part# 42724A3
