still troubled
lawrance
2 hp older evinrude junier lots of spark will not even spit for me new coil plug@wireit did run in march 09 not now why i need it for may two4 week end. much help needed. how do i check the timing and whats the jet setings.:mad:
mars bar
Re: still troubled
Did you check for spark? If so try removing the plug and squirt a little gas in the cylinder. What else happened since march?
jbjennings
Re: still troubled
the timing is checked by seeing if the flywheel key is sheared or not. If the flywheel key is intact, then it is timed perfectly. I hope you checked to see if you had good spark by seeing if it would jump a 1/4 inch air gap. Sometimes a weak coil will make a spark, but not enough inside the cylinder.
Also, are you getting fuel to the carburetor?
If I were you, I'd look at this thread for adjusting your carburetor:
http://forums.iboats.com/showthread.php?t=167352
