Re: stock prop pitch
maybe I should try running one, do any of you folks know what the WOT should be on that 69 mercruise 120hp with the #1 outdrive???
I believe my 120 i/o mercruiser, iron duke 4, has a WOT in the 4200-4400 rpm range, but I cannot say exactly as the boat is not with me now. My 120h.p engine is in a 19'6" Starcraft Holiday runabout, a 1995 model. I don't think these engines changed very much over the years, aside from breaker point ignition to electronic. Mine is electronic, but I suspect yours is breaker point style.
I do not know what prop I am running, but I am very pleased with it. It trolls down to 1.8mph at idle, around 650 rpm or so, and it runs about 40mph at around 3900 rpm. The extra few hundred rpm do not squeeze out any more speed with my setup. My Starcraft Holiday is a runabout open windshield style boat. Dry weight of the boat is only about 1600 lbs., but is has live well and a 9.9 Big Foot kicker. With fishing gear, expedition junk, full fuel, and 2 or 3 people I imagine I am up close to 2800lbs. or more when under way.
I imagine your boat is running an added 300 to 400 lbs. dry weight over mine.
I will ask my mechanic to check the prop on mine to see what it has, and will let you know what I find out. It may not be the best for your setup, but I will find out anyway.
Clay
Clay
