Stoopid lawrance
Boss Hawg
I bought a used Lowrance LCX16CI & about half the time when I power up it comes on BACKWARDS (like in reverse/mirrow image) :(
It straightins out after a minute or pushing buttons but this cant be right :confused:
Guess i got screwed? :(
wire2
Re: Stoopid lawrance
It's probably repairable. Google "Lowrance repair east Texas" and you'll find over 100,000 hits including forums with "search".
Al-53
that model is discountinued...lowrance sometimes will not repair them..they offer a upgrade...to a newer model...your unit and cash for a newer model....
make sure the the connections are clean...the power plug..the transducer and the GPS puck if u have one....wipe connectors with alcohol plug them in and make sure the connection is tight....A loose contact does strange things,,,,I know...lol.....
Al
Boss Hawg
Al
I think that did the trick :D
Why did'nt i think of that? :redface:
THANKS!!!
Al-53
hope it worked out for you.....I had the same problem....and the cleaning did it....good luck and tight lines
Semper Fi
Al
Boss Hawg
Semper Fi
Al
I guess when dealing with all this modern equipment we feel we must have these days we forget to check on obvious simple solutions to problems :redface:
SEMPER FI my freind
