Caddy_Kid
Thread starter- Joined
- Nov 18, 2005
- 113
Re: Straightening a warped boat?
Just took another look at the boat, and I see that the bow is in fact true in relation to the keel. Didnt hit me until it was mentioned that a triangle is pretty tough to bend.
It looks like it all comes down to the ribs. I'm used to seeing two piece ribs that are bolted togeather at the chine. This boat is built more like a canoe. It has one piece ribs that run from the keel to the gunwale. Because of this, these ribs naturally want to be straight. The side of the boat that is bent is the side that got the most direct sun on the inside, beating on the ribs. Mix in some summer thunderstorms with rain, and they get pretty hot and moist. Perfect combo to bend wood, or in this case, straighten it.
So what it looks like is that the starboard side of the boat has actually sagged as the ribs became more flexible. Thus dragging that side of the boat down and bending it.
It looks like this sagging occured about amidship, right behind where the front seat appears to have been. This is also where the screws are missing from the starboard side of the floor supports, which would have attached it to the ribs and probably kept it from sagging (since the port side did fine, and has all the screws in it). The screws are missing and there is a 3" gap from the ribs to the bottom of the floor support to within a couple feet of the transom.
