Strange problem with 4.3, HELP please!!
medic7156
I have a 88 205 Sundowner with a 4.3 and Cobra outdrive. When running high RPM the engine losses power when the trim button is pushed up or down . It doesn't seem to do it when at half throttle or less. I thought maybe a short somewhere but could that cause such a draw that the alt. draws that much power from the motor? and why not at lower throttle? Any help would be very much appreciated. Thanks in advance.
Re: Strange problem with 4.3, HELP please!!
Ayuh,... Sounds more like Bad Grounds than a short...
medic7156
Do you think bad ground on the trim or the engine? Any suggestions where to look first? thanks for the reply.
