olbuddyjack
- Joined
- Oct 23, 2003
- 318
Re: Strange Problem
Thats known as "sucking a valve" or a "tuliped" valve. The valve will have to be replaced. <br /><br />Its caused by high cylinder temperatures melting the valve. High cylinder temps are usally caused by lugging or from timing. As little as 4 degrees can make a difference. <br /><br />Make sure you cure the problem and not just the symptom.the exhause valve on both the dead cylinders are concave from edge to edge.
