huntingdeer
- Joined
- Jun 21, 2012
- 117
That's the idle relief hole. If you have water coming from there when you have water INSIDE the hull, the exhaust Y-pipe 'o' ring is leaking, or the pipe or housing where the pipe bolts up to is corroded and leaking. Either way, the drive needs to come off and the engine out.
If you leave it, it will get worst, and quickly.
Chris....
Well I've noticed when it's in the water it comes from the plate on the transom that is flat against the back.ive fixed so many leaks on this boat smh.... I thought it was ready but I guess it never will be.this is starting on year number 2.....I wonder if I get some bad a@& sealer and put around the outside of the plate I can get by one fishing trip to see if the boat is worth it?
Not if that isn't where the leak is...
The y pipe I don't think is leaking but it's coming from the transom eons where the lean is. The y pipe is on tope of the motor correct? I'm confused
