Stray Current Question
bruceb58
Honorary Supreme Mariner
Re: Stray Current Question
Sounds like a potential shore power induced corrosion problem waitin to happen! Glad I'm not berthed near you!
Like I said in a previous post...what proof is there that the marina's wiring is at fault?
I/O WALDO
With an ac volt meter check for voltage at the shore rec at the slip between the ground and neutral(none) and between the neutral and the water(none)
