ron7000
Banned
Thread starter- Joined
- Jul 10, 2004
- 498
after reading the two threads here about crimp connections vs. solder connections, I had to do a little test. <br /><br />There was reference to the American Boat & Yacht Council Standards for Boats that stated, "Solder shall not be the sole means of the mechanical connection in any circuit. Exception: Battery lugs with a solder contact length of not less than 1.5 times the diameter of the conductor (E9.16.K8)"<br />I think there was also references made to USCG regs about the subject, but there seemed to be a large consensus of people here that were against solder connections, for the wrong reasons.<br /><br />So I did a comparison with standard 14-gauge wire, copper stranded, not sure how many strands at what diameter per strand, with a blue rubber type insulation. The connectors used were GB ring terminals, which can be purchased from any hardware/electrical store (i.e. home depot). I did not use anchor terminals.<br /><br />Using about 8 inches of wire, a ring terminal was crimped onto each end. One ring terminal was secured to my garage door track on the ceiling with a #8 screw. The other end I slowly put my weight on, I'd estimate maybe 30-40 lbs of force. The wire slid right out of the ring terminal, as expected.<br /><br />Same senario, but with ring terminals soldered on each end, using 96% tin %4 silver solder from radio shack, and paste flux. I used a propane torch to heat the ring terminal to apply the solder, only because it was easier and faster, and I didn't feel like hunting for my soldering iron. This time, it took about half or more of my body weight, around 100+ lbs, before the wire broke after where it was soldered. The solder joint did not let go, the wire about an inch away from that gave. I also bent the #8 screw holding the ring terminal.<br /><br />Next was to try a 62/36/2 radio shack solder (2% silver, 36% lead). Maybe the 4% stuff was unfair. Nope, same as before. Slighty bent the screw holding the terminal and broke the wire, not the solder joint.<br /><br />If anyone has any doubts, I invite you to play around with this in your spare time. I will hopefully post pics tomorrow of how the connections broke. My intention is not to start a war over the subject, only point out that information in printed texts that everyone is supposed to abide by is not always correct, nor is it always the best way to do something. I know there are what-ifs and caveats, post them if you like.
