Ezrider_92356
Thread starter- Joined
- Jul 14, 2007
- 426
well here is where im at now, i have a lot of stress cracks in the outer skin of my transom. i didn't really notice them till i really got to looking, i also have several holes that will not be re used, it looks like 2 different outboards have been mounted with different bolt paturns. different accessory's that have been mounted and removed sense 1958 to now some of witch were covered with an white silicone like substance. when i laminated my new transom in the peanut butter squeezed out all of the holes. i have now started sanding the outer skin with 40 grit sand paper and everything is smooth but it is down to the glass in some spots down to the original gel coat in others and still some paint in others and the peanut butter is sanded even to everything else. i am thinking of adding a layer of roving to the outside of the outer skin and then fairing it in, is this a good idea? and does everything need to be down to the glass or does my 40grit sand paper leave enough of a rough surface for good adhesion. another thing is i want to re locate my bilge drain lower, orrigionaly the TOP part of the stringer was notched and the drain just below the floor leaving about 2 inches from the bottom of the drain hole and the bottom of the inside of the hull. i want to put the drain plug as close to the bottom as possible, any concerns with doing this?
now onto the second part of my questions, my splash well, well i screwed something up, i test fit my splash well and the curve of my transom is off about a half inch. maby a little less. i must have eather made my clamping braces wrong or i should have exaggerated the curve to account for it coming back when releasing the clamps i laminated it one layer at a time. so now my spash well wont fit quite right. my thought is, to cut off the part of the splash well that meets the transom mount the spash well in place and re-make the back part to the splash well. maby using some kind of release agent between the two or a sheet of plastic or something to avoid actually bonding the two, what are your thoughts on this. or just throw the spashwell in the garbage and take advantage of the extra room..lol, (last resort)
