Hi Folks,
I made the mistake of buying an old boat last spring without researching this forum first. You guys have helped me tremendously so far without knowing it. Too much to list. Thanks!
It is a 1985 Wellcraft 260 Aftcabin. It is powered by a Chevy 5.7l with a stringer 800. It has a power steering assisted Trucourse system. Ignoring low speed wander issues, the steering always felt erratic and clunky. The latest problem is that while we were cruising around the lake at about 10 mph we made a full right turn. The boat would not come out of the turn and before powering down I forced the wheel to Port. The steering wheel now turns easily from stop to stop. I can see a long horizontal rod behind the engine respond when the steering wheel is turned (see pics), so I believe that the helm and cable are fine. The outdrive does not respond. We got towed to the ramp and pulled the boat. The drive will tilt up and down, but can not be moved left or right by hand.
One thought is that the input gear (16) has jumped the cluster gear (17).
I realize that I probably have not provided enough info, so if you can help and need more info, please let me know how to help you help me. Again, thanks for any help.
