Stringer and deck replacement....
AShipShow
Question about the wood for the stringers. I originally thought that they were made from 3/4" ply but after some investigation on the original ones that i pulled out i found that they are in fact regular 3/4" board. I'm assuming that it was either pine or spruce but I have no real way to tell what they were made from. So the question is, should I stick with the original build and go with solid board or would 3/4" ply be sufficient in its place?
I ended up using 2x material from the home center for my stringers... The originals were 3/4 or 1" thick boards as well. If I were to do it all over again, I would use 3/4" plywood and double it up so you could span the joints if that makes sense. Would have still ended up 1.5" thick but much stiffer and more stable... My concern with the box store lumber is its not the most stable stuff in the world... Once its encapsulated in fiberglass its probably fine though.
kcassells
Ply is structural
2x stuff is not structural its dimensional. Works for some boats.
Sabin1269
Does anyone have a link for Oops! Method of tracing stringers? I read it on Friscoboaters thread that he used it but I didn’t know if there was somewhere that had more detail on it.
Sabin1269
Well wanted to give everyone an update. I just got back into the build today. I left off getting the deck on, cutting out all the new drain holes and hatches as well as putting in the tank and flotation foam. I traveled a lot for work last year and never had a chance to touch the boat but now I just cleaned it out and will be glassing over the deck this weekend. Feels good to get back in the saddle!
buxmj
Welcome back to the madness and I think everyone who has done a boat rebuild can understand about needing to take breaks in the project.
