Stringer construction
Smokin'Mo
Has anyone heard of stringers made of outer layers of plywood, say 1/2" thk each side, with a layer of rigid foam board epoxied in between then capped on top and fibreglassed over to secure to hull?
I'm looking for the best method for replacing my boat stringers without all the weight. I have also heard that the foam board is easier to shape to the hull contour than solid wood. Once shaped the foam board becomes a template for the outer plywood layers.
Any suggestions?
Mo
tashasdaddy
Re: Stringer construction
best is 2 pieces of 3/4 laminated, with a 4 foot lap.
Ayuh,........
Sounds like you're Over-Thinking,+ getting ready to Over-Build it......
ondarvr
Either product (wood, foam) will work without the other one, so decide on which one you like better and just use it alone.
D
DJ
Guest
You could use foam as a core-no wood. You'll just have to put about twice as much glass on. Lay the glass mat on a bias.
drewpster
My engine stringers are wood core. The engine and transmission mounts sit on top of the stringers secured with lag bolts. The bolt threads are no longer holding and the stringers need replacement.
If I re-core them with foam securing the mounts will be a bigger job. Will the foam hold fasteners?
D
DJ
Guest
No. You can glass wood in that area. Remember, any time you take wood out, you have to replace it with more glass than was there before. A lot more.
You could also glass in aluminum bolt plates. It all depends on how sophisticated you want to get.
I'm not a big fan of lag bolts. I know they are necessary, in some applications. If I have a way around using them, without too much difficulty, I do.
Robj
Mine had the wooden block engine mount also. I changed it and used a piece of 3/8 thick aluminum angle and through bolted that to the stringer. I did increase the stringer thickness by adding another piece of 5/8 ply in the engine bay area for more strength. Did not like the lag bolt set-up. This arrangement I think is much better. Have also seen this type of set-up on other boats with much bigger power than mine, so it must be OK.
Have a great day,
Rob
