- Joined
- Jul 7, 2010
- 15,103
I'm dealing with a shift issue that I thought I solved last year ... doh!
I have a 165 Electric Shift OMC Stringer and when I push the throttle forward or pull in reverse there is a pretty solid "wham" in the back and the entire system shuts down. It was suggested before that my drive is trying to engage forward and reverse at the same time ... and I'm thinking that might be the case:
When I check current at the shift cables entering the intermediate housing I'm getting a reading on both wires of about 20AMPs when pushing forward OR reverse. Am I correct in understanding that only one wire should be drawing AMPs when pushing forward, and the other when pulling reverse?
Also, where is the best place to check the AMPs at the front controller?
I'm still learning the electric stuff.
Thanks in advance!
Thanks in advance!
