Smokin'Mo
Thread starter- Joined
- Oct 12, 2007
- 32
I am working on a 21' Campion Discovery, 200hp Merc Offshore O/B. Floors are cut out, stringers are removed, stringer support fibreglass stripped from hull. (a cup type wire on a high speed angle grinder works great for this). My transom also needs replacing but does not have an inner fibreglass liner instead there is an additional layer of 2" plywood laminated to the 1" piece laminated to the hull and transom skin. Middle portion is rotted only on the 1". Can this be fixed without removing all of the transom plywood?
I have heard that rigid foam in sheet form can be used to model/sculpt a template from which to fabricate a wooden stringer. Has anyone heard of anything else used to fabricate stringers from other than wood?
