- Joined
- Jul 7, 2010
- 15,126
To my fellow OMC "keep it alive" guys:
I took the boat out this past weekend, and after idling out of the marina (no wake) I went to throttle up. When I did, the engine gave me a little squeak (literally sounded like a belt slipping) and the then died. I tried to start two times, but just got the starter (maybe solenoid) "click."
Swam her in, loaded up and went home. In the driveway, I tried starting and it kicked up right away and would shift (no problem) in forward and reverse. Stopped the engine. Started one more time, and it squeaked and stalled out again.
The plan (in the next week or two - gotta' busy week coming up) is to:
Does that make sense as an approach? Or is there some more obvious plan of attack?
I suspect my problem is in the intermediate as I'm pretty confident in the drive itself (it seems to be shifting fine which kind of eliminates the lower unit in my mind), and the intermediate is the thing I've paid the least attention to since I got the boat. That said - is the intermediate complicated to rebuild? And if I can locate a replacement are they different between HP ratings? (I'm digging through my manuals but haven't figured it out yet).
Any suggestions are welcome and thanks in advance.
- Remove the stern drive & try starting
- If the boat still does it with the drive removed, I'm going to assume I've got a problem in the Intermediate housing
- If it works fine with the stern drive off, I'm going to assume I have a problem in the upper gear case
