Stringer repair
bjf66
Scott
our Cyprus here is crap as has open grain, not worth putting in as fence post
cheers
Brett
bjf66
longer column for char lynn pump turned up 3 weeks ago
Needed to fabricate a bracket which supported the hydraulic pump under the dash, seen as now it would not be bolted hard up to dash
The 2nd picture shows the bracket and pump which will sit under dash, however will be tilted with a little more angle
seems strong enough, it will do the job
looking for large dish D- steering wheel approx. 12-13" Dia
bjf66
Its while since I posted update:
Bunks fitted to trailer
LED lights fitted
everything back assembled
Booked in fior road worthy certificate on Monday next week
Char lynn Helm pump fitted
Helm adaptor and Steering wheel fitted
bjf66
final touches to trailer today, in between showers finishing off the LED lights installation
Before and after shots
at least that out of way
time to look at lifting boat back onto trailer
bjf66
Went for warrant of fitness and failed on having no side lights as trailer is 2.38m (7.93'), should of done the home work as over 2.1m need the side lights
Of well ....another $18 for inspection on Friday, gives me a few days to add the side lights
Everything else check out good
had a look at the seat height tonight,
I could get away with the seat bases being 175mm from from floor, however feels more comfortable @ 125mm (5") H between seats and floor
Thinking I'll give the Garelick 77000 seat suspension a go, as they are only 50mm H, seems not many other choices out there if you want to sit on the floor with the ski boat seats
As i was looking at the seat height decided to see whether i could find some were to bolt the mercury/Kiekhaefer zero effect controllers
Made up template
will need to fabricate a mount up in gurit board and then glass
Trying to get the controls on flat of hull without mounting to close to dash
I've seen the controllers mounted with handle raking back and also forward,
With the handle sloping back I get the throttle on inside, so not sure which is correct or whether it even matters
any comments???
keep in mind, you will most likely change seat height once you get it out on the water.
bjf66
started fabricating mount for the mercury zero effort controllers
bjf66
Had to order 2* 845281 CLEVIS Control Cable hook this morning, @ A$52/each I'm in wrong job
making up the controller pod
need to measure for the 33C cables to suit throttle and crash gearbox selector 0630002009.jpg
bjf66
trailer registered this morning
at least that out of the way now
bjf66
back to trailer
decided to go with 4500lb electric winch
had to fabricate the pedestal for this, came up alright
used arc welder to stick the pieces together, tidied up and painted
bjf66
finished work earlier today, hoping to get a few hours on boat after dinner
trailer finished, time to swing boat back onto trailer
my son gave us a hand to get organised
boat sits a little higher now to climb in and out of
bjf66
boat back on trailer
bjf66
prior to lifting boat on trailer, we placed one strap under boat to try and find the centre of Gravity of the hull with engine/gearbox/drive in
still needs fuel tanks, seats of driver
However wanted to see where approx CG was
approx 1.5m from back of boat overall length 6.3m
76 / 24%
Therefore wondering whether its possible to move some of the fuel up front to distribute the weight
This is custom boat so not sure what stand it was designed to as have no information
bjf66
boat back on trailer found an important issue which I had taken for granted
Now nose of trailer up in air too much weight sitting over rear axle
now i have found centre of gravity of boat can see that pair of axles need to be slid to rear of boat approx 2 feet, this will move weight on to towbar for better balancing
ah the job for tomorrow morning
lift boat and trailer and then slide the axles to rear
pain in arse as have to redo the connection to brake lines, any them the breaks fix one issues and move on to the others one by one
bjf66
need to clean up the hull
gelcoat in reasonable condition, needs a buff
however want to get the red stickers off and the black writing which looks to be painted on
Does anyone have in ideas?
