Stringer repair
was looking for some Chev BB aluminium heads for another 556 ci short block I was putting together.
Thought I would try and save some weight approx. 35kg saving per pair between iron and aluminium
came across 2 pairs of mercury 525efi heads that couldn't say no too.
bare casting # 843425
right price
good timing
nice to scoop a good deal
remember, the mercury racing heads have a mercury racing only exhaust bolt pattern. you will need to modify the heads to fit any other BBC exhaust.
bjf66
scott
yes, I've been told the bottom few bolts are different
I get the heads next week so lets see what the actual difference is and whats required to marry heads, and exhaust
top row should be same, IIRC 3 of the bottom are different
bjf66
Picked up both sets of heads tonight
set #1: 900-843425, mercury BBC all good, bare with rocker studs and comp cams push rod guide plates
set #2: 900-843944, ha revision B on head, one of the heads had damaged lost a valve head got mashed into the combustion chamber, when I stripped head down it doesn't look that bad, needs welding but didn't touch the valve seat
valves are 2.25/1.9
set 2 head look like the intake ports are a little larger
layered over BBC exhaust gasket over mercury heads exhaust ports
The 4 bottom holes line up as normal, the top 4 holes need to be drilled to suit standard BBC exhaust bolt pattern
good buy for US$300 for both sets
bjf66
Forgot to take picture of the head prior to removing valves, however valve head had dislodged and was sandwiched under exhaust valve while closing and mashed the inlet valve into combustion chamber
managed to tap out the valves and no seat damage apart from large cut in combustion chamber
lucky
you can weld and blend that gash. the one valve guide sleeve is coming out too. that is the downside to aluminum heads in a boat, they do need to be rebuilt a bit more often.
bjf66
Scott
that could of been me when I was tapping out the valve stem as it was locked in there reasonably tight or could of been when the valve broke off and grabbed the valve stem
I tried one of the good 3/8" valve stems into the mashed chambers and the guides seem okay as valve slides up and down
not a lot of information around about these casting #'s
will get the chamber welded and blend as suggested, get guides checked out, drill the headers bolts holes for exhaust, no need to have different exhaust pattern if this can be rectified
came with beehive springs and titanium retainers, 10 degree locks, haven't measured the spring yet at the installed height
However will throw some new valves in there
bjf66
dissembled heads
inspected valve train
2.25"/1.88" valves don't look to bad once cleaned up
was able to identify the valve spring and retainers
valve springs PAC-1255X beehive/conical single springs 1.45:, installed @ 1.95" with 170 lbs on seat, which can be used with up to 0.700" lift cam,
Both the turbo cams are 0.610" and 0.650" lift @ 1.70" rockers
titanium retainers: Pac R513
10 degree locks
measure installed height and all valves measure within 10lb of each other
so at worst will replace:
16* valves
16* springs
2* titanium retainers
16* 10 degree locks
At best
2* titanium retainers (can purchase singles)
16* 10 degree locks
1* 2.25" inlet valve x 5.218" long (standard length)
1* 1.88" exhaust valve x 5.418" long (0.100" longer)
cleaned up the damaged head with gash in combustion chamber, managed to grind off the the aluminium that was damaged exposing the gash, doesn't appear to be that bad and is away from the valve seat
dropped head off at aluminium welder/fabricator who built the aluminium fuel tanks for me, should get the head back next week, then we can go form there and see whats needed, may get away with just blending the combustion chamber and possibly replacing one of the K-lines
cleaned up the good head yesterday, used oven cleaner, brake clean and WD40, managed to get all the gunk off
head looks good
ports have been cleaned up previously with light porting
there is some pitting around 2 exhaust ports, maximum 0.060" deep,
do you think this needs to be filled/welded or could use JB weld (500 degree F constant temperature) to fill
interesting its only on 2 ports
interested in whats been done successfully previously?
I don't know the history of head whether they were run in salt water and fresh water although there no corrosion on inside of water passages
assuming there was no closed water cooling
However I will be running closed water cooling system so imagine this problem will not be as severe
have the ports welded up when you get the combustion chamber welded.
bjf66
yes ports and chamber welded
not sure what the valve seats are made of suppose should try and ID them first before talking to the cylinder head machinist to ensure we put back the correct seat material
purchased some new valves spring PAC-1255X, although the valve springs I took out measure up okay at 175lb @ installed height of 1.95"
however needed to get 2 springs and retainers, which cant source locally.
will have to wait until USA PAC opens after lock down to get order in for 2 titanium retainers and 2 more valve springs
any way no drama keep going with boat
FYI, it helps to polish the chambers, so you have incentive to do that work anyway while you wait for the parts.........
bjf66
scott yes agreed, already polished a few iron head castings
these are the 990 rectangle port heads i put on the 402ci BBC
however metal comes off a little quicker with aluminium
bjf66
Exhaust and mufflers setup.
thought I would have a look at how the 4" exhaust pipes would sit now and then fabricate the inside exhaust to where I want the pipes to exit
So looking for some inspiration in determining the position of the exhaust/muffler setup for 22 ft boat
the BBC + turbo (under hatch) is fitted off the transom with inline Z-drive, crash gearbox behind motor
the rear deck/cap slopes down to transom and as my hatch is off the transom approx. 24", was thinking would run the pipes up from inside engine bay through rear deck and then elbow back to follow deck profile and then hang some gibson mufflers i have here
Understand this is a little different setup, however looking for any photos of exhaust pipes coming up through rear deck as opposed coming out of transom
anyone got anything to share
I'll post photo of the rear deck deck setup in few hours after i clear the crap of the boat
first some photos of the boat and transom and rear deck
bjf66
now the mock up with 4" pipes and mufflers
off centre 6" either side
It's a large hoke only want to cut once
thought i would ask the resident experts on what they thought??
please send comments
bjf66
well after deep contemplation while knocking back a few beers on saturday thinking what and how to do this routing of the exhaust pipes, decided to get up early on sunday and cut a few holes in the rear deck and will bring the pipes out there as opposed to through the transom
had some 4" x 15" 316 stainless 0.80" here and used a 90 degree storm water fitting to mock up proposed exhaust tails and to support muffler
remember, the sweeping elbows on the exhaust are not as tight a bend as PVC. you may end up with ovals where you have your round holes.
I would run a brace from the end of the mufflers back to the transom. would hate for you to be pounding in some chop and loose a muffler.
bjf66
originally i was thinking the exhaust tails/pipes after the come through the deck of boat could be dry no cooling water
But then thought may need to double skin the exhaust to get some cooling as pipe goes through deck
Therefore not sure whether its possible to put a cooling ring between the 4" exhaust pipe and the deck
could make this 150mm dia x 30-50mm deep (deck at rear is 20mm thick), this would have water continuously flowing through to cool the pipe around the deck
any thoughts on whether this would work ??
excuse my rough sketch
from a reversion point, you only need to run jacketed to the turbos
from a heat point, you may want to run jacketed to the muffler.
bjf66
scott
yes there will be a round plate which will be welded to the 90 degree bend and bolted through the deck, and then a saddle support bracket back towards muffler end
do you think i could get adequate cooling of the pipe if I fabricated cooling ring between deck and pipe, and had the rest of pipe outside of hull dry?
cheers
