Stringer repair
My floor is cored with end-grained balsa. You can core with a variety of materials....its just time and money
ondarvr
Has anyone any experience with the cored foam on flooring
It works well, the actual strength isn't an issue, you just need to make the top skin thick enough so you don't get any impact damage.
bjf66
No Title
well had a busy weekend took motor, Z-drive out, and proceeded in cutting stringers down
managed to take off 35mm in height, this should be plenty
The centre stringer on outside is still 230mm Hx60mm (9"x2.4"), so still plenty of strength
Gave me a good opportunity to check my lamination skills, seems a little air pocket when I was filleting the radius to blend sandwish plate into new stringer, but the rest seems okay
I was counting on how dam had this stuff was
I was using a Ryobi saber saw to cut, I broke one I had been using since the start of the boat rebuild, and then went an got a replacement under 12 month warranty, and then broke the new saber saw 1/2 day latter
Needless to say took that back and got a new saber saw, i love Bunnings hardware, great service
opened the drain holes through inner stringer so water can drain into centre cavity
Both stringers level backwards and across
Cut floor section
cleaned by some of the older chop matt in outer stringers
Will put some cloth down on the inside of the outer stringer and across on to inner stringer just to strengthen a little
In two mines to use the Gurit 13mm ore board or marine ply which I have for the floor
will fibreglass in new small centre stringer to finished off
will fibreglass top of inner stringers in fabric and Vinyl ester
More dust in garage
after cleanup
will start attacking the front section, to remove ballast tank and trim down the centre stringer
bjf66
glassed outer, inner stringer 600SM, an 17oz fabric
Deroct53
Would anyone happen to know if the stingers of a 1987 Sea Sprite 175 Fish N Ski are fiberglass or wood? I was given one and the floor has to be replaced but haven't gotten into it.
I suggest starting your own thread vs hijacking someone elses thread
bjf66
No Title
cleaned up between stringers, around floor, added 40x30mm hard wood centre stringer, to fill the void left in removing the old stringer
filleted either side with PB, needs to be cleaned up
However ready for next step to add 600 CSM and 17 or 27oz fabric along floor
bjf66
No Title
had big weekend in garage flbreglassing
saturday
- aid the (2oz) 600CSM, 3m x 0.350m long
- then (17 oz) 637 grm fabric over top 3m x 0.45m long
sunday
- laid more 600 CSM x 2m x 0.3m long on inside stringer on both sides
- then 637 grm fabric over this 2m x 0.4m inside stringer
- capped RH stringer with 600 CSM, coming over stringer either side by 0.2m x 1.5m long
starting to see end of the floor/stringers
need to make decision on whether to put the floor back of leave exposed
Purchased some other aluminium water cooled exhaust that may offer a little more clearance
I've decided I'll run the twin turbo 8.3 litre (509") BBC in boat
bjf66
No Title
bjf66
No Title
decided to cut some wings/supports between stringers, as need to support floor so thought add some strength
PB in, need to clean them up, and tab them in
not sure whether should be adding some foam under the floor for buoyancy
anyone have an opinion on when to/or not add some foam buoyancy????
bjf66
Was in discussion with another boater last week who has ocean raced 25ft mon hulls and used fixed surface drives in past
He was suggesting to use a urethane disc in between the Dana spicer flange/yoke as a shock obsorber to give drive train a little movement
The companies which were suggested were polyflex or isoflex
Has anyone used these types of flexible couplings as interested in some feedback
bjf66
No Title
after some discussion ended up purchasing the Isoflex IFC 4700HT flexible coupler rated to 2100 Nm (1550lbs) torque, 2 days delivery, US$320, nicely machined even fits on the Dana 1410 male/female universal flanges
a few pictures fitting to drive and gearbox
bjf66
No Title
tabbed in using 600 CSM the 50mm pvc pipes cut in half fr the drainage to rear
bjf66
No Title
picked up sheet of Gurit cored board, for approx A$105 with tax for 2.18x1.02x12mm sheet
cut out left hand side approx. 1500x230mmx12mm
wet board first
rolled 1 x 2oz CSM and 1 x 18oz fabric onto bottom,
took approx. 0.5kg of resin
made sure the the cored board was siting on straight supports
will most probably use for top floor boards 2oz CSM + 33oz fabric, should be strong enough
will do the top glassing tomorrow
bjf66
No Title
foaming plan:
Now starting to look at how to go about the placing of pourable foam under floor
so will pour foam into the pockets where have supports on inner stringer
Now thinking about how to pour the foam into outer stringers, marked in red on attached photo, as far as Im aware this stringer is open moving all the way forward, although most probably easier to cut a hole into floor and see if I can get my phone in there to have a ,look
Im assuming would cut some 50mm Dia holes at 1 metre lengths and pour in at different interviews
I calculated I needed:
open stringers: 1.2kg each side
Red cavity: 1.2kg each side
Green cavity: 6.6 kg either side
approx. 16kg not incl wastage...20kg
Not sure whether I should be adding the foam up into the bow?
Have been looking at Ecofoam GP330, approx. A$330/20 litres
http://media.erapol.com.au/wp-content/uploads/files/products/foams/Rigid/GPFoam/Ecofoam GP330.pdf
Or does anyone know of a polyurethane foam which is more closed cell??
bjf66
one other question I have
I haven't touched the front half of the fllor of boat, as stringers were in good condition
therefore the cavity under floor is open
There are no drainage pipes there
would i be best to
1. just pour the foam into cavity, as back half under floor has drainage pipes, working on principle the water should run to back of boat ?
2. cut into floor and add the drainage pipes and partly remake floor as I have in rear of boat, prior to pouring the foam?
Or any other suggestions???
Pour foam.....go boating....you wont have the boat 20 years from now
