stringer replacement
rdsr
can formed plastic be used instead of wood and can they be fiberglassed in ? thanks
fishingdan
Re: stringer replacement
No. They should be wood or structural foam board. Neither epoxy or polyester resin still well to plastic. The easiest is plywood. Encapsulate the wood with epoxy and glass it to the hull. It will last a very long time. <br /><br />Here is a nice little tutorial:<br /><br /> http://bateau2.com/content/view/144/28/
surlyjoe
you can make box stringers out of fiberglass so you dont have to use wood, they are basically a inverted fiberglass "U" glassed onto the inside of the hull. you almost have to make some wood ones anyway to use for molds tho...
mikemerrill50
scrumbler, how many layers of glass would you recommend for that? how many mat, how many roving? thanks!
