Dan_A
- Joined
- Aug 15, 2019
- 25
1998 Falcon Thunderbird
Finally have my project boat back in hand.
I have cut out all the rotted stringers, however they were only partially rotted. They were fully encased in fiberglass but at some point a previous owner threw some screws through the floor into the stringers allowing moisture to penetrate. The rot runs from the front of the engine bay to the foot locker, and only in the two innermost stringers. Everything else is completely solid. I have read a lot of posts about stringer repair over the last year and see that most recommend taking the cap off and doing a full replacement. In this case I do have the means to do this so I have been looking at the method of sistering butt joints adhered with epoxy. It seems it would work in this case.
My current question is this: When using this method, are the sister boards adhered to the hull with thickened epoxy along with the primary stringer, or do they “float” over the hull and just act to support the joint?
