Stringer Trim issue
oldsub86
1973 Starcraft Holiday 18 with 140 HP Stringer.
Trim motor will lower the front of the engine but I just hear a click when I try to raise it back up.
I am assuming that if the motor runs in one direction, there is not likely anything wrong with the motor.
Any advice on where to look first?
Howard Sterndrive
Re: Stringer Trim issue
remove and clean the terminals at the relays - file or sand them shiny- also file the terminal side of the nut.
that's a start. After that if still no go you can do voltage drop tests if you know how and have a meter and a helper.
dying motors do tend to still work ok without load (e.g. lowering) and show their issues when under high load (e.g. lifting an engine)
