supercab78
- Joined
- Sep 6, 2004
- 158
Stringers or lack of in a 1975 18 ft Searay
I'm in the process of repair part of a floor that has lifted up on one side. After remove some of the floor I noticed the foam between the floor and the hull had split length ways thus allowing one side of the floor to move up 1/2 inch, step on it, it goes down. In the center is a long sky compartment. I,ve been poking around and except for the 3/4" plywood that makes up the side of the seven foot long sky hole( which are not even one piece)I can't find any stringers that go beyond the engine compartment. Does the foam that was injected between the floor and hull give the boat hull it's strenth? Thanks Jeff
