strip down help needed
piperdog
hello,ive a brownband 35 hp ,the drive shaft is stuck/siezed into the engine.
ive demolished the gear box and got the mid section off okay .ive tried soaking it ,swearing at it and even saying sweet nothings to it ,where do i go from here...thanks piperdog
Chris1956
Honorary Supreme Mariner
Re: strip down help needed
Can you hand the motor, driveshaft up, a few inches off the ground? If so, spray some PB Blaster around the driveshaft and let is work over several days. I little heat and cooling cycles will tend to suck the oil into the joint.
You might try turning the driveshaft opposite to the motor's operation just in case the splines are somewhat stripped.
