Hi folks, I'm new hear and was hoping I might get some advise. I have a 1987 Force 85hp outboard and it has a stripped lower unit drain plug. This is the small hex key drain plug in the front lower end of the gear housing, there are also a vent plug and a fill plug on the upper side of the lower unit.
Does anyone have any idea's or advise as to how to remove it without dropping the lower unit. Do i dare try to use an eze out to remove it while it is assembled. Thank you for any wisdom you will share.
