nola mike
- Joined
- Apr 22, 2009
- 5,519
Screwed up a stripped out aluminum exhaust manifold a couple of years back. See this thread (http://forums.iboats.com/forum/engi...utdrives/594065-stripped-out-my-thread-repair) Anyway, started leaking again, changed the gasket again, and noticed that my new bolt wouldn't torque down. Not leaking yet, but it will, so I need to be prepared to fix. What is the likely failure point of a helicoil insert? I'm guessing that the threads I tapped in the aluminum have stripped, and the insert is just spinning freely. If this is the case, I'm thinking that the insert will pull out fairly easily (maybe thread a bolt part way in, and make a puller out of it), at which point I can retap with the next larger/correct size insert. Any other ideas?
