Stripped screw
gbb
The upper drain screw( gear oil) to my lower unit is stripped out. What can I do? :eek:
F_R
Re: Stripped screw
The life blood of the outboard mechanic---Heli-Coil. But I gotta tell you, it has to be straight or it will leak. You might as well get a pro to install it. To do it yourself, you will have to buy the expensive tools. (How the heck did you strip it out anyway? Never mind, just wondering.
psteurer
Re: Stripped screw
I wonder if he means the head is stripped. It sure would be hard to strip the threads on a drain fill screw. If the head is stripped, the best way to get the screw out is to use an impact screwdriver. I bought an inexpensive one at Harbor Freight and it did the trick.
gbb
Re: Stripped screw
No, the threads are stripped. I just got the boat and motor late 2007. Last year when I change the gear oil, I notice coiled alum on the threads. I replaced it with a little longer screw and it seemed to tighten. But this year found a little water in the oil.
kbait
Re: Stripped screw
If that longer screw seems to get a good bite, I'd probably get a new gasket for it, and perhaps add an appropriate sized o-ring. It will seal, and it shouldn't be able to vibrate out if the new plug screw has a good purchase in the hole. I don't know the cost of bringing the LU in to have a heli installed, but above fix would be a time-buyer at least..
