Stripping a jon boat
anthony95
is it ok to strip my jon boat in the winter meaning will it still work good at takeing the paint off only 2 coats of thin paint? and will one gallen of aircraft paint striper do the job?
THANKS!!
Ned L
Re: Stripping a jon boat
It takes a lot longer for chemical strippers to work in cold weather. Where are you located? I 'd probably try just a small area at first to see how it goes. I generally will use paint & varnish remover in only warm weather for just this reason, & I am well experienced with it (will usually buy 5 gallons at a time just to have it as various projects come along).
etracer68
Ensign
We have used stripper in the cold, but it worked best using a heat lamp.
THANKS!!
Ayuh,.... Welcome Aboard,.... Why, do ya wanta Strip it,..??
If ya want to paint it,.... Just sand it smooth, 'n repaint it....
That way, ya don't have to spend a Fortune on the specialty primers....
Woodonglass
Ditto this ^^^^. Well stuck paint does NOT need to be removed. ALL Bare aluminum must be primered with Self Etching primer and then another coat of Metal Primer. If it ain't broke Don't fix it. In your case just sand and recoat!!!:D
anthony95
well i went a head and got the stripper bc i flipped the boat over and there was bare aluminum all over and on the inside it has a lot of bare spots idk if i should post this next question some were els but on my jon boat were the motor goes on on the back there is wood on both sides of the boat on the back end is it hard to remove and replace it ? i will have some pics tommarow to add to show better what i mean
fishrdan
If it's anything like my jon boat, I'd want to strip it first if I wanted a good paint job. The paint isn't stuck to the aluminum well as they didn't prime the aluminum, they just squirted on some flat camo green paint and rolled it down the line. Tape will peel the paint right off the hull, even painters tape lightly applied will pull paint :rolleyes:
anthony95
its a coming off all cracked all over and flaking so just wonted to get it all smooth for a nice paint job and i found a lot of rust underneath the paint so i am going to get that off
jbcurt00
On my jon boat were the motor goes on on the back there is wood on both sides of the boat on the back end is it hard to remove and replace it ? i will have some pics tomorrow to add to show better what i mean
Yep, pix will help, since we don't know what kind of jon boat, hard to say how hard it'd be to remove the transom wood, let alone how to remove it however the previous owner installed it...
But no, normally, not hard to remove & replace. Which you'll like want to do anyway so you can assess the boat's skin under the wood, and prep/paint that area when you paint the boat. NO PRESSURE TREATED wood during put back. Whatever you use, you'll want to make sure it is well sealed (inside any thru hull bolt holes too). Often the hull under poorly prepped & installed transom wood, is not in good shape, esp if it's pressure treated.
Rust? Usually jon boats are aluminum alloy (tinny's). Often fish hooks & other metals are left in contact w/ the aluminum & as they rust the rust stain is left behind on the boat. But its hard to envision hull rust under the paint.
A possible cause may be a leak that was repaired w/ steel mandrel'd rivets or steel rivets, and then to coverup the repair, the boat was painted. The steel shouldn't have been used, but w/ care & maintenance, bottom paint may have been enough to prevent rusting.
Any loose paint definitely should be removed, and as was suggested above, etching primer, primer then paint, and prep prep prep before & after each paint stage. Lots of good painting aluminum boat info around..... Use the advanced search function in the iboats webpage header....
BTW: We're talking about removing non-original paint, applied after it left the manufacturer right? OEM paint is much harder to remove....
Welcome to the iboats dry dock....
