Strong Glue
JamesCoste
I'm not sure if this is a technical question, but I'll ask anyway.<br /><br />What type of glue will help affix the sole of a shoe to the leather uppers?<br /><br />I bought a pair of golf-shoes at Good-Will for $5. They are my first pair and I didn't want to spend a forture. I played in them 5 or 6 times and they leather part of the shoe has started to separate from the sole.<br /><br />Other than that part of the shoe pulling away, the shoes are comfortable, give me a good grip during my swing, and are, etc.<br /><br />I'd like to repair them.<br /><br />What kind of glue/adhesive should I use?<br />Where can I get some of that product?
Wreck Rider
Re: Strong Glue
There is a polyurethane glue sold at almost any hardware or home renovation outlet now that would be great. I have house brand, I think the national brand is Gorilla Glue. It has so far worked on rubber, urethane, nylon fabric, wood, leather, acrylic for me (just like the label claims!). Recently glued some sport sandals that were separating in the same way your shoes are, seems to be working fine. Lent it to a colleague who wanted to glue a heel back on her shoes, seems to be working fine.
LubeDude
Re: Strong Glue
Originally posted by JamesCoste:<br /> <br />I bought a pair of golf-shoes at Good-Will for $5.
Dont you love taking it to the establishment? I shop at goodwill and second hand stores all the time. I was out of town last winter and realized that I had forgotten to take my work cloths so I went to a second hand store of some sort, it was real nice but it wasnt a good will store. Anyway, they had some great shirts my size that were like new. I did buy some work cloths, but I also bought five really nice dress shirts for $2-3.00 each. I dont have a problem with it at all.
kenimpzoom
Re: Strong Glue
Use the glue Elwood used on the accelerator pedal on the "Good ole Boys" Winnebago.<br /><br />Its "strong stuff"!<br /><br /> :D <br /><br />Ken
ED21
Re: Strong Glue
Got any epoxy laying around?<br />I've used it on shoes before.
jsfinn
Re: Strong Glue
I used a knock off of Gorilla glue for some project a while back.. it expanded as it dried ... it's strong as heck but might want to think about that when using it.<br /><br />Superglue would probably do it.
JamesCoste
Re: Strong Glue
I heard that Gorilla Glue was good. I'll try some once my shoes dry out a bit. I definitely don't want it to expand though. Now to find out who sells it.<br /><br />I have no problems buying stuff from Good-will. Now that I know that golf-shoes do actually help, I'll get some nice ones for my birthday or something if I can't fix these.<br /><br />I also got a nice pair of dress-shoes, about 50 golf balls for $2, etc.
Holdimhook
Re: Strong Glue
All the big retailers (WalMart,Lowes, Homedepot) sell either Gorilla Glue or the knockoff.
Re: Strong Glue
I've had Great Luck with "Goop",......<br />I find it at the Check-outs at H/D, or Lowes.......<br /><br />It's Alot More Flexible after it dries than Gorilla Glue,.... Which becomes quite Rigid,.. And Porous.....
Boomyal
Re: Strong Glue
I second Bondo's Goop. Great stuff, you'd be surprised at the number of things that you can fix with it. They used to make several variations of Goop. Shoe Goop, plumbers Goop etc. I don't know if the still do and I really wonder what the actual differenc was between them. <br /><br />Don't use Gorilla glue. It may work but there are 3 problems. One Bondo mentioned. Two, any squeeze out will expand like crazy and would be hard to trim because it is pretty hard. The third and big reason is because it is very expensive and has a very short shelf life after you open it. It would be a big waste unless you were to use it constantly.<br /><br />The Goop keeps pretty well.
BoatBuoy
Re: Strong Glue
From a shoe repair forum (yea, I didn't know there were any either):<br /><br />If the sole is leather or rubber, and the shoe is leather, <br />you should be able to glue it yourself...You need an all purpose contact cement. See if there is a shoe shop close by and maybe they sell it. If you can't find a shoe shop, try a hardware or home improvement store and they may have it. Barge Cement seems to be everywhere, see if they have it. Rubber cement may be labeled as Contact cement, but don't use that because it isn't durable enough. <br /><br />When you use contact cement, you need to make sure both surfaces ( the sole and the shoe leather) are clean...If you have a piece of sandpaper, use it to clean the surfaces, and even rough it up somewhat... apply the glue evenly to both surfaces..You need to plan some open time to let the two sides dry or cure.<br /><br />When the glue is dry, make sure that you line the edges up correctly, then press the two sides back together. If you have some kind of clamp, you might use it to keep some pressure on the glue while it dries more. (to keep from damaging the shoe you could use a piece of heavy paper like a grocery bag or some cloth between the clamps and the shoes.) clamping it or letting it dry for at least a couple of hours will help. <br /><br />A more advanced tecnique would be to let the contact cement dry and reactivate the glue with heat from a hair dryer or heat gun. warm it up, don't burn it! and then press the two parts together. (Heat makes the glue more tackier.) When the shoe and sole is warm, don't clamp the sole hard, because it may cause it to squish if it is rubber ...wait for a couple of minutes, then clamp it.
one more cast
Re: Strong Glue
I remember one time my dad actually built up some worn out soles with shoe goop. He was one of 13 kids in his family during the "great depression" and he didn't throw anything away.
JamesCoste
Re: Strong Glue
I'll look for he Goop stuff and try it. The gorilla glue looks like good stuff for the purpose. I definitely need some flexibility in the shoe once it has set.<br /><br />Glad I checked back before shopping.
KRS
Banned
Re: Strong Glue
I believe that Goop is a silicon adhesive, at least it smells like it.... and did you say golf shoes? Golfing directly interferes with fishing time, GET YOUR HEAD ON STRAIGHT! :) :) :)
RPJS
Re: Strong Glue
Any good contact adhesive will do a good job.
SS MAYFLOAT
Re: Strong Glue
The Goop or another brand called E6000 that has a model glue smell works excellent. I think it has a stylene base. Repaired many Tennis/Golf shoes for the locker room attendant at a country club I use to work for. It dries like silicone, but is harder and still flexible.
lakelivin
Re: Strong Glue
I've glued soles using goop befoer. worked fine. clamping to get approximate even pressure over the area being glued is another issue.<br /><br />Instead of clamping, I used a 25 lb weight plate on top of the shoe (or lighter if the sole is rubber & you don't want to compress too much). even better, maybe you could put in one of those 'shoe shape saver' wood inserts, center it over the repair, and then put the heavy plate on top of the shoe.
crazy charlie
Re: Strong Glue
I did the same repair on my bowling shoes with "Shoe Goo".It worked great.I recently bought something called Goop which was surely inferior to the Shoe Goo.Charlie
