fishmen111
Thread starter- Joined
- Feb 1, 2008
- 637
'97 Wellcraft 160CCF. I was mounting a second battery in the back today and when I drilled, out shoots the water. Pee stream out of my deck...hmmm. Not the original design I'm sure. Out come the hole saws and after multiple cuts, I have water on top of my foam. I drain the water and core the foam. It is not wet. It crumbles to a fine dust that floats very well actually. I know my boat is 185 pounds heavy so I have more water somewhere. In my search, I am thinking of adding some 1.5x3' hatches. Is foam put in every void before the cap is put on? Is it sectioned? I have contacted Wellcraft for schematics to no avail. This boat is not old enough nor did I pay enough to do an extensive restoration for 185 lbs. Ideas? Thanks as always.
