- Joined
- Jul 18, 2011
- 19,649
I know that the topic of resolving structural moisture ( in transoms, stringers, bulkheads, foam chambers, etc) in a "pre-rot" situation comes up on this forum from time to time. I myself have raised the issue with my current boat. Conventional wisdom is to cut & gut the affected areas and replace with new material. All to often this issue comes up in a pre-purchase or immediately after purchase scenario.
I happened to see a thread on another forum of someone in the buying process (used boat) who came across a candidate boat with structural moisture issues and it was recommended to him ( & the seller) to use a company & process called "DryBoat" ( www.dry-boat.com ).
Apparently this process involves pumping very dry (desert like) air into the moisture laden areas of the boat and drying it out. Then everything is sealed up. While I see some draw-backs to this process, in that by no means would it guarantee that rot would not set in at a later time, it is interesting to see this process as a commercial offering for boats with moisture problems.
Just wanted to share, as I was quite surprised to see it as a commercial process and wondering if others have heard of or seen it . . :noidea:
Nothing came up on this site when I did a search for 'dryboat'.
