JASinIL2006
- Joined
- Feb 10, 2012
- 5,758
I've begun the job of replacing the trim senders, shift cable and bellows (u-joint and shift cable) on my Alpha One Gen 2 drive. I hope to reuse the exhaust bellows and the water inlet tube, in addition to the gear lube monitor.
I've been able to get the shift cable out, the senders off, and the hinge pins removed. I have removed the u-joint bellows from the bell housing side, as well as the exhaust bellows (also from the bell housing side).
It looks like all that is left to remove so I can get the bell housing out of the way is the water hose and the gear lube monitor but I do not see instructions for how to get and remove these. I have the Mercruiser service manual for the drive, and I'm trying to follow the directions (in section 4), but I'm stumped.
How do I get at the water hose and gear monitor hose so I can take off the bell housing completely?
Thanks!
Thanks!
