DamianJP
Thread starter- Joined
- Mar 25, 2008
- 612
Hey guys
Ive done some searching in these forums and also see other people having trouble with removing the power head. Its a 1977 55hp Evinrude and its giving me problems. I made a makeshift A frame with a chain pulley and its not poping off. I tried to heat the seam between the adapter plate and head, also sprayed penetrating stuff into the seam. Also heated the back aft nut stud and solvent too.
I have all 8 bolts and 1 aft nut off. Also have the Lower unit dropped.The chain pulley is lifting up hard on the power head, its crazy how it not coming off. This has got to be the original gasket and seal. 30 years of heating up and cooling down.
Im getting me very pissed off , its driving me nuts. Multiple rounds of heat and penetrating solvent and taps by a wood piece and small sledge while the pressure of the chain pulley too.
Also I had the adapter plate bolts out of the back part and the part effortlessly came up a small bit with no problem. This top powerhead gasket is on like it was permanently put on.
Mabey someone has any info that will help me get it off.
Thanks,
DamianJP
Thanks,
DamianJP
