Struggling
awilson07
I finally have most of the boat cleaned out (well to where I’m satisfied enough) but I’m having a heck of a time getting the old foam and wood out from behind the two back corners. Any suggestions?? Please and Thankyou in advance. Here’s a few pictures of the whole thing.
First, pull the motor as you need to redo the transom
Build a craddle
Use a cup brush to remove foam
KJM
Wow, from the mess you started with, you already got a lot of work put into this! I don't know anything about aluminum boats, but a lot of people hear will and have good advice. Don't give up!
awilson07
Show the model number on my motor is a E40ELC0 but I cannot find anything on it except for a motor model number that is E40ELC0B. Is that the same motor? Thanks in advance.
jbcurt00
Ask motor questions in the correct motor forum
Evinrude/Johnson correct?
