First Post - I just picked up a 1970 Slickcraft SS-204 with the inline 6 165. It is a Michigan freshwater boat and always stored indoors. The boat is in beautiful condition and I bought it knowing it hadn't been in the water in 4 years and knowing I am facing a complete fuel system cleaning/replacement and could be facing a complete repower.
I have two questions:
1) The engine is stuck. It was drained, but apparently not fogged. Does anyone have a clever suggestion for loosening up the engine after soaking the cylinders. It doesn't seem like I can get to the crank pulley due to the front engine mount. I've read a suggestion to pull the starter and try to move it with the flywheel. - any other ideas?
2) The previous owner (whom I know and am 99% certain is a trustworthy person) stated it was running fine with no problems prior to storage. Assuming I loosen the engine, get it running, and the compression is good - is there any reason to do an overhaul (other than peace of mind)?
I am willing to pull the engine and overhaul it, but would obviously rather not if unnecessary. I just wonder if the cylinder rusting from a stuck engine would be significant enough to damage the cylinders, rings, etc. and I would be better off to do the overhaul now rather than damage the engine by running it (again, assuming I can get it running).
Thanks for your help.
