It's a 1986, 6 cylinder.
The bulb is always firm, and it has plastic floats. I get gas to the carbs but not into the engine. So I removed the bowl cover on the lower carb and found that the bottom of the float had gone above the float pin guide and lodged the float on an angle against the inside of the bowl wall and the top of the gude pin.
It is a new motor to me, could they be the wrong floats, or do the valve seat levers need adjusting, or something else...........................Help please, thanks
