Re: Stuck in mud or snow
Actually,.......It has Nothing to do with the loading of the axles.........
And,... It's very True that you Should do Hard Pulling in Forward gear,+ Not Reverse......
The 3rd Member, or Pumpkins, or Differentials,....Are Designed to transmit the Maximum power in Forward.....
When you Load a Ring,+ Pinion in Forward,.. The Pinion is screwed Into the Ring Gear....
When you load the gear set in Reverse,... The Forces are screwing the pinion Out of the ring gear....
The housings are Not designed to handle the Outward load,+ I've seen the Pinion actually Blown right Out of the Housing.........
If you're going to Pull in Reverse,.... Be Careful......
Pulling in Forward,..... Go for It.......
