Stuck mower coupling
Bob_VT
Re: Stuck mower coupling
Your link will not work but I understand.....
Soak it with pb buster and possible a LITTLE (little) heat from a propane torch because that shaft runs through a seal......
Maybe a puller, pb buster, heat and a slight tap with a hammer. If all else fails and you are not going to re-use the part...... use a grinder to cut it down and slice it to the shaft.
