Stuck on Engine Alignment
andrewterri
those are some rough looking mounts. I was lucky that i did not have any rust or corrosion to deal with. Do you see any reason I should not coat the studs and nut heads with bearing grease or 2-4-C? My thought is if I do that it will help prevent corrosion.
achris
More fish than mountain goat
My preferred libation on screws, nuts, bolts and studs is 'Aqualube'... Way more water-proof than 2-4-C....
And yes, those nuts look manky, but I can guarantee they will unscrew with the same ease as the day they were put on....
Chris...........
andrewterri
And that's all that matters Chris. They can keep their new shiny looking parts then fight with them when they corrode. Thanks again...
